Manual Trans VSS HELP!
Old Dec 24, 2005 | 11:39 AM
dyrt's Avatar
Car: 86 Regal Limited
Engine: 95 cop lt1
Transmission: t56
Axle/Gears: 8.5" gn/3.73 gears
i have searched but i can not find answers concrete enough to decide which manual transmission to use(i would like to use a tremec tko) with my 96 iron head lt1. can anyone here answer the following?
1. does anyone know what signal frequency the tko puts out, and also the right units(pulses per mile/revolution)
2. i have gathered that the t56 puts out a 17 pulse per driveshaft rev. is this right?
3. does the aftermarket t56(bolt to a normal bellhousing) put out the right frequency, or is it a mechanical output only?)
i have several reasons that i would like to use a tko, but mostly i would just like a new trans that i can bolt to a normal bell housing since i am using 4th/3rd gen hyd. clutch parts to operate it. since it has both mechanical and digital outs it would be ideal so i can run both the computer and my mechanical speedo.
if anyone can help me out i would appreciate it.
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
