Th350 and detent cable
Old Dec 28, 2005 | 01:41 PM
racingdragracer's Avatar
Car: 1969 camaro
Engine: 90 TPI
Transmission: 400turbo
I need a part # for a detent cable that will work in a turbo 350 that will hook up to a tune port intake.
Old Jan 1, 2006 | 02:48 PM
91Z28TTOP's Avatar
Car: 91 Z28 CAMARO
Engine: 305 TPI,stock
Transmission: 700R4, 2800 stall
If memory serves correctly the 350 is kicked down buy the modulator connected to the dizzy.
Old Jan 3, 2006 | 07:01 AM
Car: 1969 camaro
Engine: 90 TPI
No. The th350 has a kickdown in the same area as the 700r4.
But the 700 cable won't work because the end at the trans is much bigger.
It hooks to the throttle the same but the end is too big.
Old Jan 3, 2006 | 08:35 AM
91Z28TTOP's Avatar
Car: 91 Z28 CAMARO
Hopefully someone else in here has had the same problem and can help ya out.
Old Jan 3, 2006 | 05:47 PM
CrazyHawaiian's Avatar
Car: too many ...
Lokar makes one but its expensive
Old Jan 4, 2006 | 06:55 AM
Car: 1969 camaro
Engine: 90 TPI
I see that lokar makes ones but you have to use their throttle cable and their bracket.
Old Jan 4, 2006 | 12:01 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
You could try a detent cable from an 81 Camaro, pn 25507541. The bracket will probably need to be modified. GM never matched a TH350 to TPI engine, so your deal is trial & error.
Old Jan 4, 2006 | 12:55 PM
Car: 1969 camaro
Engine: 90 TPI
Is that cable supposed to be longer?
Old Jan 4, 2006 | 08:28 PM
Car: too many ...
I used the Lokar one with the stock TPI bracket on my 89 IROC-Z L98 and the stock throttle cable. They dont know what they are talking about. But I eventually took the cable off because I'm gonna convert the tranny to full manual.
Old Jan 5, 2006 | 06:53 AM
Car: 1969 camaro
Engine: 90 TPI
How did you get it to work.
do you want to sell the cable?
Old Jan 5, 2006 | 10:24 PM
ljnowell's Avatar
You should be able to go to any parts store and ask for a universal th350 kickdown cable. Its adjustable in length, and the end should work in the same bracket the TV cable was in on your TPI setup.
Old Jan 5, 2006 | 11:09 PM
Car: too many ...
I dont remember it being a problem, it was adjustable as mentioned and hooked up to the stock bracket. I dont even think I have it anymore, gotta look around. The Lokar cable is overpriced if you ask me. I would go for a cheaper universal cable. Unfortunately for me nobody around here had one that would work so I had to order from the Internet.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
