snap ring help
Old Dec 30, 2005 | 08:28 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
snap ring help
i am having trouble getting the snap ring out, i am putting a shift kit in my friends car, and i was wondering if there were any specialty tools that i would need, right now i am trying to use needle nose pliers. any help would be good. -jon
Old Dec 31, 2005 | 05:43 AM
ede's Avatar
ede
try snap ring pliers
Old Dec 31, 2005 | 12:09 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
I've never had to remove a snap ring to put a shift kit in a trans.
Why are you? I'm guessing you have one bad *** kit to install and if your trying to install a kit that involves that much dissasembly and don't even have snap-ring pliers, I believe you might be in over your head like my son! he called me and I had to go to his house and finish the job starting with the valve body, screws, seperator plates, check ***** and everything else in the trans pan!!! Hey, you never know, I've seen a friend rebuild a 350 TH sitting on a board on a trash can in his front yard!
LT1Formula
Oct 8, 2015 08:34 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
Numbah-1
Oct 2, 2015 08:27 AM
