how do i find out what the drive gear is on my th350
Car: 82 z28
Transmission: TH350
Axle/Gears: 10 bolt 3.73
i need to find out how many teeth are on my drive gear so i can calculate what driven gear i need what is the easiest way to figure this out? do i just take off the tailshaft and its right there?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I think all you need to do is pull the tailshaft off to see the speedo drive gear. They're usually color coded so you just need to know what color it is and what color you need to correct the speedo.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Remove the tailshaft. The drive gear is held onto the output shaft by a special clip. Count the teeth. After being in hot trans fluid for one or more decades the color has a way of changing, greens go blue, reds go pink. I worked dealership parts counters for many years & found you can't rely on the color, unless it's a new gear.
