Clutch Won't Disengage TKO Swap
Old Jan 2, 2006 | 07:15 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Well, I got it all together today & fired it up & it won't go into gear with the engine running & wheels locked. Wheel s jacked up it goes in all gears except reverse, hit the brakes with the clutch pedal in & it stalls the engine. Here's the lowdown, I swapped a 700R4 for a Tremec TKO 600. I used a Mcleod bell, flywheel & clutch, 69 Camaro fork & short TO bearing, 3rd gen hydraulics, 4th gen pedals, adjustable ball stud, all brand new. I am getting 5/8" travel at the slave cylinder, the ball stud was adjusted so the TO bearing just kissed the clutch fingers with the tie strap still installed. If 5/8" is normal travel then I have to rethink the mechanics of this setup. I am not sure how much the clutch fingers need to move to disengage the disc. I am going to check on this tomorrow. Any insight would be appreciated.
Old Jan 3, 2006 | 11:19 AM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
Re: Clutch Won't Disengage TKO Swap
the 5/8 travel should be plenty, its almost certainly a problem where your not close enough to the clutch to disengage it
its possible that any of your adjustments are off, the TO bearing is too short, the bell is too long, or the flywheel has been resurfaced one too many times (i did that this past year lol)
Old Jan 3, 2006 | 01:00 PM
Ricktpi's Avatar
Like I said, the TO is touching the fingers of the PP. This has been verified by using a mirror to look into the fork hole. All the parts are brand new, including the flywheel. I fabricated a bracket & welded it on the bell for the slave cylinder. Everything was done to ensure proper alignment & everything appears to be working. The only thing I can come up with is the 69 Camaro fork needs more travel than the T5 one does.
Old Sep 12, 2006 | 09:31 AM
FullSendRacing's Avatar
Car: '85 Trans Am FAILBIRD
Axle/Gears: 4th gen torsen 3.42
Did you ever come up with a solution for this? I'm having a similiar problem. Not quite enough throw on the clutch to fully disengage - I can shift when I rev match but otherwise it's rough
Old Sep 12, 2006 | 07:50 PM
Ricktpi's Avatar
Yep, got her straightened out. Got a custom length, bolt on hydraulic TO bearing & adjustable master cylinder from McLeod. Not cheap, but it works perfectly. If I had to do it all over from scratch, I would get the bellhousing & slave assembly from 5speedtransmission.com & use the stock master cylinder.
E Rod
Aug 28, 2015 05:17 AM
Hello, Michael
Aug 20, 2015 03:19 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
jharrison5
Aug 19, 2015 05:53 PM
rsrmoore
Aug 7, 2015 08:44 PM
