clutch for a t-5
Old Jan 6, 2006 | 10:31 PM
383firebird84's Avatar
Car: 84 firebird
Engine: 434ci
Transmission: turbo 400 3500 stall transbrake
Axle/Gears: 10 bolt 4.10 spool'd
clutch for a t-5
i have a 84 firebird right now its a 6cyl 5 speed i built a 383 stroker dynoed out at 554 hp at 5500 rpms i would like to put the motor in the car and keep the t-5 from the 6cyl in there for now but i need help with clutch what do i use. i have a v8 bellhousing and i have 456 gear with a spool also so the cluch needs to handle the power and gears plus slicks
thanks ryan
Old Jan 7, 2006 | 05:09 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
with that much power, 4.56 gears, and slicks, you might as well kiss the stock rear end and the trans both goodbye because you are crazy using either of them. dont waste your time even putting the motor in until you at least have a trans that will hold up.
also do you realize that the v6 trans has a pretty low 1st gear? with 4.56 gears you will be grabbing 2nd gear before the first 60ft assuming the trans even lasts that long.
Old Jan 7, 2006 | 05:51 PM
Shake Zula's Avatar
Car: 1986 Olds Cutlass Supreme
Transmission: 200-4R
Axle/Gears: good question...
Dont bother. Im swapping out mine right now. And first gear would be good to like 20mph anyway, it would just slip the clutch and burn it up. Thats what mine did
Old Jan 7, 2006 | 08:37 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
If you do definetly never think about giving it over half throttle..... Not sure what you were thinking on this buildup man, maybe you shoulda thought about a more mild 400hp 383 or so with a drivetrain you can unleash the fury on insteada going all out like you did.
Old Jan 7, 2006 | 08:39 PM
Car: 84 firebird
Engine: 434ci
but what clutch do i use the rear is built to handle it i really dont care if the tranny blows up i prolly wont race it with the v6 tranny just want to get it moving untill i can gather up some money for a auto
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
