hurst 1/4 stick shifter
Old Jan 10, 2006 | 12:01 PM
bitchin85camaro's Avatar
Car: 85 camaro
Engine: 327
Transmission: 350, 6200 stall, w/ brake
Axle/Gears: soon to be strange 5.14
any pictures of this shifter installed? (yes i already searched) im most likely going to buy this shifter because i am swapping to a manual reverse valve body.
Old Jan 11, 2006 | 03:04 AM
Night rider327's Avatar
Car: 1988 Camaro
I have the B&M pro stick in mine (just about the same as the hurst 1/4 stick)
I don't have any real good installed pics of it but heres one where you can see it.
To fit it, I had to grind out/cut part of the shifter plate's light housing, install a "spacer" bettwen floor and shifter. I made the spacer out of some old scrap metal flat bar and bent it to sit off the floor about 3/4" to 1". Used longer bolts and put bolts through shifter, the flat bar and floor pan.
Attached Thumbnails hurst 1/4 stick shifter-picture-424.jpg
Old Jan 12, 2006 | 11:27 AM
Car: 85 camaro
Engine: 327
thnks for the heads up. looks pretty good
Old Jan 12, 2006 | 04:46 PM
Car: 1988 Camaro
Thanks man. I like the feel of the pro stick & 1/4 stick better than any other shifter, and it looks diff. in a third gen to say the least. You see mega shifters in these cars everywhere
ZEEYAA
Apr 16, 2023 08:29 PM
ndndndnd
Sep 28, 2015 08:00 AM
