s-10 5spd
Old Jan 11, 2006 | 07:04 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
s-10 5spd
i saw somwhere on the boards about using a 5spd from a s10 pick up.... what i need to know is if the main shaft splines and length are the same as well as the drive shaft yoke and splines ... bell housing,clutch,shifter and tranny mount are not a issue.how ever gear ratio may be...all of the trannys ive gone through so far didnt really need first gear, so is the first gear in the s10 like the old 4 speed pickups?we used to call it a granny gear... dont really need that... thanks in advance for advice and help....tao
Old Jan 13, 2006 | 11:39 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
hummm...looks like ill have to do it just to see ... due to cash flow (and a blown v6) when i first got the car i didnt know about the twist in the bell housing and tranny so ive got a normal looking set up (no 15 degree counter clockwise mounting surface)in fact i didnt know about the engine being offset to the passenger side and installed the engine dead center (which is why i had to shim the pass side eng. mount almost a inch)but if it works out ill post the results....if not i wont want to talk about it...lol
Tao
Old Jan 15, 2006 | 06:26 PM
2-toneTA's Avatar
Car: currently a 99 sable, and an infamous 98 4.3L 5sp S10
Engine: 220+4.3L, and a 200hp 3.0L
Transmission: 5sp nv3500, and an axn4 AT
I am not sure off the top of my head, but I am sure I saw this over on mys10.net. I can look for you, but I will need to know what year of s10 it is. My 98 uses a 11" clutch disc with a 1.125" shaft and 10 splines. IDK about actual trans length, although I think there are many different length driveshafts. I know my nv3500 will bolt up to your car using my flywheel, clutch, and other stuff. You will just have to take the wire off my truck to hook to an electronic speedo. Hope this helps, and see....an s10 guy does have place here apparently
Andrew
Old Jan 17, 2006 | 11:05 AM
Drew's Avatar
Completely different, won't work, waste of time.
Old Jan 25, 2006 | 06:52 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
from what i can see they are completly different....but what are the problems to be over come?... just bought a s10 for $75 so knowing what wont work would save me time...if it dont work ill just put the s10 back together and sell it....or drive it till i can over come the tranny issue....tao
Old Jan 25, 2006 | 07:48 PM
Drew's Avatar
The case is entirely different... The shifter on a S10 T5 is at the middle, right behind the gears, and the tailshaft is about 6" longer. The Camaro/Firebird T5 has the shifter at the rear. Also there's no provision for a torque arm mount on the S10 transmission.
In other words, its completely different and not worth the trouble.
Old Jan 26, 2006 | 09:52 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
ahhhh i under stand now...thanks...i could over come all but the shifter location...guess ill be driving a s10 for awhile...take care...tao
Old Jan 26, 2006 | 01:09 PM
2-toneTA's Avatar
forgot about that, sorry....when they drop the fbody trans in the s10's, you have to move the shifter farther back. I am sorry, complete lapse of sanity for a moment.
Andrew
Old Jan 27, 2006 | 10:15 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
we must be related...im actually considering moving the eng back to get better balance but that will be once after i take it off the street for good...tao
Old Jan 27, 2006 | 06:28 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
taonindo
never argue with a idiot .... they will drag you down to thier level and then beat you with experiance ...
That's so true
Trevor Tarry
Sep 15, 2015 02:04 AM
5spdcamaro
Aug 28, 2015 02:12 AM
Dquickshift
Aug 12, 2015 06:21 PM
Fhakya
Aftermarket Product Review
Jun 24, 2001 07:26 PM
85IROCTPI
Dec 11, 2000 05:53 AM
