Transmission questions
Old Jan 13, 2006 | 11:01 AM
WckdDudeMan's Avatar
Ok here comes some questions and info.
I have a 1985 firebird, with vin# has it as a v6 but its been swapped for a 350TBI. What is the trans#?(4 speed automatic)
What were the 3speed automatic transmissions available and what years/models?
How is the bar that connects the trans to the rearend attached?(Havent gotten up under the new car cause I forgot to have anyone leave me a jack)
Old Jan 13, 2006 | 11:05 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Your 4 speed is probably a 700R4. The only 3 speed automatic was the TH200C available in 82 and 83 I believe.
The end of the torque arm is in a rubber bushing inside a bracket bolted to the tailshaft housing of the transmission.
Old Jan 13, 2006 | 01:13 PM
Thanks for the info, does anyone have the part number for the Hurst Adapter kit? I found the B&M one, but havent found a part number for the Hurst one.
(Just collecting info for my project, thanks I wasnt sure on the transmissions of the 3rd gens and newer....)
Old Jan 13, 2006 | 11:13 PM
Just remembered to ask:
Is the transmission electronically controlled or is it mechanical?
Old Jan 14, 2006 | 12:07 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
700R4 is a mechanically controlled transmission with an electronic torque convertor lockup..
Vintageracer
Jan 10, 2020 05:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
redmaroz
Aug 16, 2015 11:40 PM
