Help, need source for 9-bolt diff. cover plug
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
I need a new differential rubber cover plug for my 9-bolt rear end. The local GM parts guy says the part number is 10041025, and it's discontinued. Does anyone know where I can find one, as gmpartsdirect.com doesn't carry it.
Thanks.
Thanks.
Car: '85 TA
Well, the search is off. I decided that since I'm not getting anywhere I'm going to buy the TA Performance 9-bolt cover. At least it has a screw-type filler plug and not a rubber one.
You could always just go to the parts store and buy a transmission pan drain plug from in the Help! section. No point in outsmarting yourself, or doing some kind of extra work or something drastic like that.
Car: 2006 Silverado 1500
Engine: 5.3L
the correct number should be 10033568 and it's still available. there are 8 dealers alone in california that show it in stock.
Car: '85 TA
How could the part number be that far off? This is the 9-bolt you're talking about, right? And is the gasket (12523445) the correct part number?
Engine: 5.3L
the number he looked up is right next to the number you needed in the picture. the number he gave you is for the cover bolts. i'll have to look up the gasket number in the morning as i just left work a little while ago.
Car: '85 TA
Oh ok, that makes sense. The gasket is probably correct then, because gmpartsdirect lists it as a gasket. Thanks for the help.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Help, need source for 9-bolt diff. cover plug
1992 Trans Am
May 10, 2023 07:19 PM
