Just want to make sure it fits...
Old Jan 21, 2006 | 08:25 PM
kaptinkafeen's Avatar
Just want to be sure that this rear dif cover will clear a Z28 rear swaybar.
It's jeg's aluminum rear end support cover made by LPW racing products. product # 619-301-7.5G or look here:
http://www.jegs.com/webapp/wcs/store...chItemId=14493
No issues with the main bearing caps?
Thanks for any info.
-Andrew
Old Jan 22, 2006 | 02:02 AM
Night rider327's Avatar
Car: 1988 Camaro
It will fit but you probbly will have to take the sway bar off to get cover on.
The Z28 should have a larger dia. rear sway bar than my 88 RS does, and I just got my TA alum. cover to slide in between the bar and rear end.
Here's 2 pics of mine installed. http://community.webshots.com/photo/...41290424mByxEX
http://community.webshots.com/photo/...41290424pwglKb
Old Jan 22, 2006 | 07:42 PM
Thanks nightrider,
So by pulling the sway bar down, - this will aid installation and besides this, there are no clearance issues?
TIA
- Andrew
Old Jan 22, 2006 | 11:39 PM
Car: 1988 Camaro
kaptinkafeen.. Yeah no other clearance probs than that. The bar and cover will both fit once one, but it's a tight fit to put the cover on with the bar still there cause of the way you have to angle the cover and slide it into place, but once sitting flat on rear end then the bar fits back good with a slight clearance between the cover and it.
Old Jan 23, 2006 | 07:05 AM
-Andrew
Bubbajones_ya
Aug 31, 2015 12:02 PM
lt1z350
Aug 28, 2015 05:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
