LS1 driveshaft in a 3rd gen??
Old Jan 23, 2006 | 02:08 PM
4RCEPWRD's Avatar
Car: 82Z28
Just wanting to make sure that this is correct. Ive got an 1982 Z28 with the stock ds in it but am wanting to upgrade to an aluminum ds. True/False I can take a ds out of a 4th gen LS1 and it will bolt on no probs to my 3rd gen. I know ive read on these boards that its totally true but i called my local camaro shop today and they said it was impossible? but those guys are kinda backwards so I just wanted to doublecheck from my 3rd gen brethren first b4 i went and dropped some cash on one.
thanks
Old Jan 23, 2006 | 02:33 PM
No it will not work in your car.
If you're able to use the drive shaft that came in your car, then the one for ALL OTHER 3rd gen cars, and 4th gens as well, will be about 2" short.
If you had a 83-up car, or at least if you had a 700 or T-5 or T-56 in it, you WOULD be able to use the LS1 drive shaft.
Old Jan 23, 2006 | 03:20 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sofa,
Unless I misread, he's running a 350 and 700R.
JamesC
Old Jan 23, 2006 | 07:41 PM
4RCEPWRD's Avatar
Car: 82Z28
yes i am running a 700R4, so it is possible then? and if so would it just be a direct bolt on replacement or would there be any mods i would have to make?
Old Jan 23, 2006 | 08:20 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Just bolt it in, no diffenence if its a 700R4, T5, T56 or 460E.
Old Jan 24, 2006 | 06:18 AM
Yes, I missed that; I got stuck on
Sorry about that.
But as I said, and others as well, with a 700 in it (NOT stock), and the right drive shaft for THAT in it (NOT stock), the LS1 will replace it. Direct swap.
sweet_87_iroc
Sep 25, 2015 10:01 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
reiderz iroc
Aug 13, 2015 04:57 PM
