Wont go into gear.
Old Jan 24, 2006 | 01:53 PM
sasser43's Avatar
Car: 89 GTA
Engine: 350 TPI L98
Wont go into gear.
OK, yes ive searched and can't find how to fix my problem, so heres the whole story:
The car at times when i stepped softly on the gas would wait until really high rpms until it shifted so it would jerk into gear. I didnt think anything of it b/c it only did it 3 times. The car sat for a couple of weeks because i had to find time to replace the smog pump which the bearing had worn out in. Once I did, the belt was running smoothly and everything looked good. I took it to the gas station to fill it up and on the way there it would only do first and second gear. So i just left it in second on the way there which was only a mile in a 45. If i put it in D or (D) it would shift into third and just rev and i would have to shift it back into 2nd. So I came home, looked on here and thought it would be the TV cable that needed adjusting. Well I tried, and maybe I'm jsut an idiot but it didnt work for me. The only button i saw wasn't shaped like a "D" and was a square that is very hard to push. The cables seem a little loose and sometimes the throttle wont close all the way back and will hang. It seems like the top cable isnt pulling back on it or something. So ultimately I just pulled on the cables and now it wont go into any gear, it just revs.
Now can anyone help me?
Old Jan 24, 2006 | 01:54 PM
sasser43's Avatar
Car: 89 GTA
Engine: 350 TPI L98
the tranny is a 700r4
Old Jan 26, 2006 | 11:48 AM
sasser43's Avatar
Car: 89 GTA
Engine: 350 TPI L98
any ideas?
Old Jan 26, 2006 | 12:37 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
TV cable seriously misadjusted or broken or the trans is shot, needing a rebuild.
Old Jan 28, 2006 | 03:45 PM
sasser43's Avatar
Car: 89 GTA
Engine: 350 TPI L98
Can u tell me how to adjust the tv cable like im an idiot? Because i follow the guide to it on here and i get nothing.
grngryoutmyway
Oct 18, 2016 05:48 PM
gord327
Oct 3, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Jlanz55
Sep 29, 2015 08:55 AM
mfp189
Sep 27, 2015 09:25 AM
