pic of my pinion hehe
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
well the pic below my typing is my pinion shaft that came out of my 84 posi disc rear end. So i guess its time to buy my richmond 4:10s ive been lookin at. Here is my parts list. let me know if i forgot anything.
Richmond ring and pinon, 4:10s, 3:23 carrier and higher
installation kit for that ring and pinion
new rear end cover (i may sandblast the old one)
cover bolts
and some misc. stuff i need cause the rest oft he stuff was in such bad shape.
calipers
rotors
energy suspension poly bushing kit
KYB gas-a-just shocks
Also what would you guys reccomend to use to clean out the posi, brake cleaner?
cover bolts
calipers
rotors
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
Originally posted by rjmcgee
Buy a solid pinion bearing spacer from Ratech. You don't want to put a crush sleeve back in it.
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
dimented24x7
Sep 17, 2015 06:58 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
