6/18, 7/21, 7/22
Old Feb 1, 2006 | 09:12 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
6/18, 7/21, 7/22
After many hours researching this, I've come to the conclusion that one of those 3 speedo gearings are what I need to get back on track. I run a 3.73 10-bolt with 16" tires and T5 tranny. I have no idea what gears I currently have. Any opinions on which one would work?
I'm curious also, this car had a 2.77 when I bought it. The speedo was under by a bit. I had the speedo recalibrated at that time, could this effect the gears I install to correct the problem this time?
Thank You..
Eric
Old Feb 2, 2006 | 12:27 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
I'm just looking for an idea before I go to the local GM store to order the parts. I appreciate any advice on this subject. Thanks again for the input.
Old Feb 2, 2006 | 12:48 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
16" tires - I assume that's a typo and you meant 26" tires.
In that case, your best bet would be the 7/20 combination.
7-tooth drive gear - #14071731
20-tooth driven gear - #14090593
The driven gear might be hard to find so in that case you'll have to go with the 21-tooth driven gear - #14090594. But that would give you a noticeable deviation on your speedometer.
Hope this helps.
Lou
Old Feb 2, 2006 | 12:56 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
Thanks Lou. Yes that was a typo. I meant to say I have 25.65" tires or "16"s.
88Z350
Aug 23, 2011 02:00 PM
goomaan
Jul 18, 2008 11:17 PM
Kevin91Z
Mar 25, 2008 08:32 AM
KagA152
May 5, 2004 06:18 PM
'91 RS vert
Aftermarket Vendor Review
Aug 24, 2002 08:49 PM
