Speedo Gears for T-5
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
Ive been searching everywhere for several hours, and cant find any part numbers for what I need. No stores or dealers have a clue. I need speedo gears for my M39 T-5, 3.73, and 275/40/17 tires. The calculator at http://www.hanlonmotorsports.com/t5speedo.asp says I need 6/18 or 7/21. They don't make a 6 tooth drive gear do they? I thought it was just 7 and 9. Any help is greatly appreicated
Car: 4
Engine: 6
Transmission: 5
7/21 sounds believable. That's the stock combo for 3.73 IIRC, i.e. whats in my car.
Search this forum for my userID and the phrase "SMUC", and learn how to calculate what you need yourself.
Can't help you with part #s. Sounds to me like you need to find a dealer with more educated people behind the counter. I don't ever have any trouble coming up with them when I need them. They definitely exist.
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i found one
http://www.chgoautopts.com/
part #14090594, it comes with the sleeve, so its a little bit more $, but i got one
Car: 92 RS Convertable
Engine: RAMJET 350
Transmission: G-FORCE T-5
be carefull you don't get a ford set the ford drive gear rotates the other way, at least when compared to the electronic spedo set in a '92
Ryan
Ryan
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
no, thats a gm number. i got it today, its 29 years old, in original packaging, so i assume that same style must have been used in t-10s?
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
