T-5 to T-56 Slave Cylinder Swap?
Old Feb 4, 2006 | 02:25 PM
Overspendin''s Avatar
Car: '88 IROC Convertible
Engine: ZZ4 TPI
Transmission: 5 spd.
Are the two units compatible?
Can I just remove my T-5 master/slave setup and install the T-56
ot are there other issues?
Old Feb 4, 2006 | 11:57 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
heares the thing...the T-56 hyd setup will work, but you need to use a modified LT1 pedel assy., an alterinitive to this is using a T-5's master cylender, a T-56 clutch line, and a aftermarket slave cylender for a T-56, which due to the fact the T-56 one dosen't have a bledder screw you have to use. The one I know offhand is made by breakware, the part # is 10380, and is made out of allumnium, which is an added bonus, they are all held togeather by roll pins and all the fittings are the same size
Old Feb 5, 2006 | 12:36 AM
Engine: 383
sorry...I hit the back botton
Chuck84TA
Jul 15, 2016 09:05 PM
db057
Aug 22, 2015 08:17 PM
Hello, Michael
Aug 20, 2015 03:19 PM
redmaroz
Aug 16, 2015 11:40 PM
cRoe4
Aug 7, 2015 08:46 PM
