Clutch Housing Cover
Old Feb 4, 2006 | 02:39 PM
n8sz28's Avatar
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
do you necessarily need a clutch housing cover. i know some of the 5 speeds had these but do you need them for a t56?
Old Feb 21, 2006 | 12:08 AM
n8sz28's Avatar
Car: 85 camaro z28
do you need this part cover flywheel housing. or is it not necessary?
Old Feb 21, 2006 | 07:56 AM
You don't "need" it, "necessarily", in the sense that the car won't work without it. But it's a REAL GOOD IDEA to have one.
You can re-use your T-5 one. IIRC when I did the swap in my car, I had to drill & tap 2 of the 4 screw holes for it though. Maybe all 4, I don't recall for sure, I'm sofakingdom I probably couldn't have counted them right at the time, much less remembered the number this long. The holes in the T-5 cover don't line up exactly to the holes in the T-56 bell housing. There's bolt bosses in the BH in the right place, just not machined out; all it needed was D&T, and it was all good.
Old Feb 23, 2006 | 12:52 AM
n8sz28's Avatar
Car: 85 camaro z28
does anyone know where i can get one of these parts. because i do want one.
Old Feb 23, 2006 | 05:45 AM
GM, junkyard.
Old Feb 23, 2006 | 12:34 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Discontinued from GM.
Old Feb 23, 2006 | 01:50 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
I don't think they are discontinued for the t56. I just ordered one yesterday. I't supposed to come in tomorrow. It was about $7 for the shield and 65 cents each for the 4 screws. I can get the part numbers when I get home.
Old Mar 2, 2006 | 09:59 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
well it turns out it was discontinued. I'm just going to make a cover out of aluminum.
jtwoods4
Sep 3, 2015 05:39 PM
Formula_88AE
Sep 3, 2015 01:47 PM
tonys91rs
Sep 2, 2015 07:07 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
