dana 44
Old Feb 7, 2006 | 12:31 AM
greenmachine116's Avatar
Car: 89 iroc
Engine: 454
Transmission: th 400
dana 44
I have a dana 44 that was made to fit in a third gen f-body im wondering how much abuse can these take it has no c-clips thick axles and a 8.5 ring gear. This thing looks pretty stout. Does any body have any expirance with one of these and do they hold up well.
Old Feb 7, 2006 | 12:38 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It was never offered in a production third gen. The SLP Firehawks used them and GM offered the diff from the GMPP catalog.
Yes it has an 8.5" ring gear which is very strong. That's similar to the larger 10 bolt diffs. The bolt in axles means there's no c-clips to worry about similar to a 9 bolt or the ford 9".
Personally, I doubt you could break one for a long time compaired to the tiny 10 bolts under so many third gens. This is the ultimate diff for the third gens that was offered by GM. The only step up from the Dana 44 would be a 12 bolt (only slightly stronger) or a Ford 9".
The Dana 44 is a popular 4x4 diff so there's a big aftermarket source of parts.
Old Feb 7, 2006 | 01:00 AM
Car: 89 iroc
Engine: 454
well a have a 89 iroc with a gm performance parts 454 ho rated at 425hp over the winter i added a single plane intake and a big shot of nitous going to spray 200hp. On motor the car runs 11.80's i figured it would run in the tens on the n20. Well i have a choice of the dana 44 or a 9 inch i bought off a friend. I would rather run the dana 44 over the 9 inch. The car will be on a drag radial do you think that this will be pushing the limit of the dana 44
Old Feb 7, 2006 | 01:27 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
if you have both rear ends i would sell the dana 44 and pocket the money rather than chance breaking it. Especially since you said you had a ford 9" rear end as well. The Dana 44 rear ends sell for 800 to a grand easily. I've used a lot of Dana 44s in fullsize chevy off road rigs and break them just as often as the 8.5" ten bolt axles, so I'd push the 9" for better durability at the cost of a little more weight.
Old Feb 7, 2006 | 01:32 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Is the 9 inch set up for a thirdgen though?
Old Feb 7, 2006 | 01:38 AM
Car: 89 iroc
Engine: 454
thanks for the replys the 9 inch is in the car now just got done bolting it in. Im thinking about selling the 9 inch to run the dana 44. My car is a cruise night slash occaisonal trip down the track type car I torn bewteen which one to part with. The reason IM pushing towards the dana is ive have a set 5.5 backspacing pro stars and the 9 inch is set up for a wheel with 4 1/2 backspacing and also would have to change gear ratio in 9 inch The dana has a perfect gear for me a 3.54 the 9 inch has a 4.30 just weighing the pros and cons of each
Old Feb 7, 2006 | 02:48 PM
iroc22's Avatar
The Dana 44 is a very strong axle. The Ford 9 inch is stronger, but it absorbs more power than the Dana 44.
Old Feb 8, 2006 | 11:54 AM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
so figure $1000 for a nice dana 44 vs. $2000 for a 9"...
i got a built 10 bolt, but i know thats gonna go, id like to upgrade to something that will take a bit more of my abuse.
Old Feb 16, 2006 | 10:03 PM
anthony714's Avatar
also a ford 9 inch will eat up roughly 3 percent mor ehp than a dana or a 10 bolt,so you loose there,also you add about 80-90 with a 9 inch,.again going backwards arent we???loosing power and adding weight???..i got a daana 44 and keeping it.its all redone.the guy who had it befor eme ran a big block in the 9s w/o a problem so i think youll be able to
Old Feb 16, 2006 | 11:26 PM
xpndbl3's Avatar
Car: 1984 Z28
i saw a car mag run a ford 9", chevy 12 bolt, and dana 60 on the same car and it ran within .1 of each different rear end in the quarter with the same gearing. So I don't know if I believe the 9" uses more power than a 12 bolt or if it's even a marginal change.
Old Feb 17, 2006 | 07:14 AM
anthony714's Avatar
all of those rears would eat up more power than the 10 bolt or a 44....PLUS YOU ARE TALKING MARGINAL LOSSES BUT IF YOUR ARE LOOKING FOR EVERY ADVANTAGE WHY GIVE IT AWAY BUT RUNNING A REAR YOU DONT NEED.PLUS FORD REARS SOMETIMES HAS DRIVESHAFT ALIGNMENT PROBLEMS DUE TO THE LOWER PINION EAR SET UP AND SOMETIME THE BIGGER REARS HAVE CLEARANCE ISSUES ON THE FLOOR PANS
sailtexas186548
Jan 19, 2016 12:21 PM
Americanmouse
Sep 7, 2015 12:10 PM
Chevy3shitty
Sep 1, 2015 09:22 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
MENINBLK
Aug 5, 2015 11:58 PM
