What 3.73 install kit to order???
Old Feb 7, 2006 | 01:53 PM
patricktroyz28's Avatar
Car: 1991 Z-28
Transmission: 4L60
Have been looking for 2 days now....and the more info I see, the more confused i get!!
I have 1991 Z-28 stock rear, with 2.73 posi, so what I have figured out is that I need a 2-Series carrier that is10-Bolt Ring and Pinion with Install Kit.
I an getting lost with teeth and spline numbers, so quite simply, spend my money, what do I order on Jegs or Summit to have a complete install kit??
Thanks for the time, I just dont want to order the wrong stuff!!
Old Feb 7, 2006 | 02:40 PM
ede's Avatar
ede
nothing from what you said, you have a ring and pinion, posi carreir and an install kit. what else do you think you need? you already have a 2 series carrier posi carrier so unless it's broke i wouldn't get another. if it is broke then get another like you have. what are you wanting to do, or what do you think you need to do?
edit: i'd get a solid spacer instead of a crush sleeve
Old Feb 7, 2006 | 02:53 PM
SleeperFromHell's Avatar
Car: 92 RS Vert, 86 Iroc
Engine: Blown 350
Transmission: Slushbox
"Cough" get a stall
Old Feb 7, 2006 | 03:19 PM
Car: 1991 Z-28
Transmission: 4L60
Well i was looking at this from Jegs, a GM 7.5'' 10-Bolt Ring and Pinion Packages 3.73 Ratio with 41-11 Teeth, 3.125'' Head Bearing 1.438'' Diameter, 27-Spline Pinion, 7.5'' Diameter Ring Gear. It also comes with a Richmond Gear complete installation kit, two quarts of Red Line 80W140 differential lube and a 4oz. bottle of Jeg's own limited slip additive. Each installation kit includes pinion and carrier bearings, pinion and carrier shims, pinion nut, crush sleeve, pinion seal, cover gasket, gasket sealer, ring gear bolts, thread locker sealant, marking compound and fits Fits 3.08 and numerically lower (2-Series) carrier.
It is item 555-60010K on jegs, just wanted to know if this the correct one to order, or is there a different one that I should get?
Old Feb 7, 2006 | 03:54 PM
Car: 1991 Z-28
Transmission: 4L60
or is it just as simple as ordering on Jegs item 836-49-0007-1K , Richmond Ring & Pinion Packages GM 10-Bolt 3.73, 7.5" 2-Series, Richmond complete installation kit; 2 quart bottles of Richmond limited slip lube; a tube of Mr. Gasket sealer; a tube of thread locker; and one container of marking compound??
Old Feb 7, 2006 | 04:39 PM
Engine: Blown 350
Summit racing...
Gears :
RMG-4900071 - 3.73 205.95
Install kit :
RMG-8310441
Your welcome
Old Feb 7, 2006 | 05:30 PM
Car: 1991 Z-28
Transmission: 4L60
Thanks Bro! Whats your paypal, I could send ya a little something for your time!
Old Feb 7, 2006 | 05:40 PM
Engine: Blown 350
Don't sweat it. Save your money for a stall next. You'll thank me later
Old Feb 7, 2006 | 05:45 PM
Car: 1991 Z-28
Transmission: 4L60
Well again!!
hectre13
Dec 11, 2023 08:14 AM
toronto formula
Nov 10, 2015 06:17 AM
hectre13
Aug 26, 2015 08:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
