where does the speedo hook up at?
Old Feb 9, 2006 | 12:05 AM
killer89ta's Avatar
Car: 89 trans am
Engine: lB9w/ tbi
Transmission: t-56
i did a t-56 swap...i know it's the driver side where the wires connect to the tranny for the speedo but which one? and how does it connect? do i need to customize it to fit with different connectors?
Old Feb 9, 2006 | 02:44 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
the sensor is just under the shifter, next to the driveshaft. It is a weatherpak connector that simply snaps in and if you are using the stock 89 harness, then you will need a late model pigtail since they are actually smaller.
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Derrick86
Oct 1, 2015 05:12 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
