I need a 3.73 posi for my '91 T/A? Where's a good place?
Old Feb 9, 2006 | 06:27 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
I need a new differential
I need a new ( or used with warranty ) differential for my '91 T/A. Who sells them?
Thanks.
Old Feb 9, 2006 | 07:45 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
are you talking just the limited slip differential or ring and pinion also? you've tried www.summitracing.com, right?
Old Feb 9, 2006 | 09:47 PM
Car: 1994 Trans Am
I just need a stock replacement differential. As for if I need the ring and pinion, well I have no idea yet.
Old Feb 10, 2006 | 06:59 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Are you talking about a complete rear axle or just the differetial? The differential is the part inside the rear that connects the axle shafts & holds the ring gear. Differentials, ring & pinions, & install kits can be had at 100s of place on the net, including Jegs, Summit, Martel bros., Moser, etc. Complete used rears can be found at salvage yards, Ebay, TGO classifieds, etc. New 12 bolts & 9"s at Moser, Currie, Strange.
Old Feb 10, 2006 | 05:11 PM
Car: 1994 Trans Am
I changed the post topic to "I need a new differential for my '91 T/A." I guess it reverted back to the original.
But yes, all I need (that I know of so far ) is the differential, not the gears.
Old Feb 10, 2006 | 11:33 PM
rwdtech's Avatar
what exactly happened?
Old Feb 11, 2006 | 11:52 AM
Car: 1994 Trans Am
You mean, what's wrong with the differential? Or what happened with the edited post?
With the differential, I guess the tech-guy said there was too much back-lash. He says, "Supposed to be a human-hair's amount of movement or less, but there's 4-human hairs worth of movement".
As for the post, I changed it but it didn't stay.
Old Feb 11, 2006 | 04:36 PM
rwdtech's Avatar
what was the exact measurement of backlash? you could probably drive it for quite some more time without worrying about it. backlash occurs in your ring and pinion though. the pinion gear is a cone shapped gear with a rod on the end that attaches to your driveshaft. the ring gear is in the shape of a circle with the gears on the side of the circle, not on the top. thats the best i can describe it. its not too common to have backlash in your spider (differential) gears.... you could probably fix the backlash by adjusting the pinion depth and such (there are also shims for the ring gear)
Old Feb 11, 2006 | 09:46 PM
Car: 1994 Trans Am
All I know is what they told me, what I wrote above. I wish I could tell you more, as I do not want to spend more than I need too.
Here's maybe something that might help you deduce it, there is a noise whenever I drive it....obviously, right. Buuuuuuut I remember a couple months ago, and even in the last few "burnouts" I only left 1 mark. I know my rear is posi because I have opened it up and saw it. Now is that normal? I don't think so. Even when I leave my apt complex, I turn out and floor it. Only the passenger side makes smoke usually. But when I do a burnout and hold the brakes, both will eventually spin.
I don't know if that tells you anything.
Old Feb 11, 2006 | 10:22 PM
rwdtech's Avatar
the springs or friction discs have gone bad. has the car always had limited slip additive?
Old Feb 11, 2006 | 10:41 PM
Car: 1994 Trans Am
I don't know. I just intalled it 2 months ago and have nothing but problems from it. Eventhough the seller "swore" to me that it's 100%AOK. When I installed it, I added limited-slip additive. I didn't put in the GM stuff. I didn't even know about it honestly. But next time I will.
Now is that and the "backlash" problem the tech told me about on the same part, the differential? Or does it sound like I need a complete diff, gears, and everything else?
From the sound of it, what are my options? If I have any.
Old Feb 11, 2006 | 10:45 PM
Car: 1994 Trans Am
Here's a pic of the posi. Not mine of course. If you can reference stuff to me, that would help out. I can understand colors and shapes
http://www.metrocast.net/~gvdb/class...series28wo.jpg
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
