rear question after rebuild
Just rebuilt the rear in my firebird have a question how much slop is expected with axles moving in and out of the carrier after the c -clip is installed I have a good 1/8 inch to a quarter of an inch? is this right?
Kenny
Kenny
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
JamesC told me to flip the c-clips, so the slightly worn part is on the opposite side. I think I had 1/16" slop or so.
If your c-clips are 1/8" thick or so, (the norm), then theres no point in replacing them.
What about the grooves on the axles? check those?
miss anything when putting it back together? How's your cross pin look?
Cross pin, axle grooves for c-clips, and c-clips themselves basically control your side-side play.
just replaced everything except the carrier
it was a rebuild and unfortunatly tonight I made the mistake of going down a hill and not quite making it over the top with the limited slip started going sideways some gave me a love tap and helped me out.........
I wonder if a posi rear would have been able to grab in that situation?
kenny
kenny
hectre13
Dec 11, 2023 08:14 AM
Eric-86sc
Apr 3, 2016 03:52 PM
hectre13
Aug 26, 2015 08:17 AM
