TH350 change over Bracket - B&M users come in.
Old Feb 17, 2006 | 05:44 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
I have the B&M bracket, but I only have the section that bolts to the tailshaft iwth the torque arm mount on it.
Does anyone have detailed pics of the part that extends the tranny mount to the stock location?
Does anyone know the best solution to the problem.
Im open to all suggestions.
Are there other crossmembers ('82 200r4) that will meet the th350 trans mount location? I have never installed a tranny before so I do not know how things line up.
I would be willing to custom fab the extention peice if I can get measurements and some pics.
Old Feb 18, 2006 | 01:49 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
it's like 4 inches by 6 inches and 1/8" steel thick has a bend in it as well to raise the trans a bit. don't have any pics presently though.
Old Feb 18, 2006 | 04:54 PM
CrazyHawaiian's Avatar
Car: too many ...
Spohn makes one, I'm sure others do too.
Old Feb 18, 2006 | 07:06 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
I dont think Im going to purchase one. I just want to fab one up. Looks pretty easy, I just hope someone that ordered one could help me out with a few pics and exact measurements.
Old Feb 25, 2006 | 04:05 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
bump for a pic of the B&M trans mount bracket peice.
Old Feb 25, 2006 | 04:29 PM
xpndbl3's Avatar
Car: 1984 Z28
isn't there a pic on the B&M website? or if you wait about 4 more days I'll jack the car up and snap a pic.
Old Feb 25, 2006 | 06:44 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
If you wait a couple months mine will be out of the snowbank and ill get you some pics/measurements.
Old Feb 25, 2006 | 09:09 PM
bad90rs's Avatar
Car: 1990 rs
Engine: 350HO
Transmission: 350th soon
Axle/Gears: 323
can i use the factory trans crossmember with this swap? my car had 700r4 in it.
Old Feb 26, 2006 | 06:35 AM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
If you get a TH350 with a 9" tail shaft it will be the right length.
Old Feb 27, 2006 | 06:10 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
I have this trans crossmember from a 700r4 v6 car. I am using the th350. Is this crossmember the same as a 700r4 v8 car for a 92? I also have this poly trans mount in the pic, the bolt doesnt fit through the crossmember, is it normal to have to widen it?
Attached Thumbnails TH350 change over Bracket - B&M users come in.-trans-crossmember-mount.jpg
Old Feb 27, 2006 | 06:41 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Has anyone ever used a 200c 1982 tranny crossmember in a newer 700r4 car like my 92 with a th350? What is supposed to make that bracket line up correctly with the th350 mount point, does it bolt in the same holes?
Old Feb 27, 2006 | 08:59 PM
xpndbl3's Avatar
Car: 1984 Z28
the 200c bracket will work with a TH350. Otherwise you need a V8 bracket and the B&M conversion for it.
Old Feb 27, 2006 | 09:38 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
So you are saying that the crossmember I have is not the same as a v8 bracket. If so, whats the difference?
Old Mar 1, 2006 | 02:39 AM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Blackroc, the crossmember doesn't bolt to the tailshaft does it? Just wondering, it's about 3 years since I installed a TH-350. I bought the Hurst kit last week but haven't even started my engine/tranny swap yet. I thought sure everbody says to use the short tail.
Old Mar 1, 2006 | 06:03 AM
Blackroc86's Avatar
Car: 1986 Iroc
My car is a 1986 Iroc Z that originally had a 305 and 700R4 in it. When I swapped to the TH350 I used a 9 inch tailshaft one and the B&M kit and it worked out for me.
I don't know about the v6 cars or the onese that had the 2004r's in them.
Old Mar 1, 2006 | 08:00 AM
elky74's Avatar
Blackroc, how did you handle the kickdown cable? I read in this forum that it was not needed, that you could manually downshift. Would you have to do convert the valve body for manual shifting? I noticed TCI's Super Pro rebuild kit has a manual/auto kit with it, but was wondering if it's necessary. Seems like the more I read on this conversion the more confused I get.
Old Mar 1, 2006 | 08:05 AM
Blackroc86's Avatar
Car: 1986 Iroc
You can use the kickdown cable on the TH350 tranny. It is not a TV cable like the 700R4's have. It is just a kickdown cable. I don't use one as my car is mostly a track car.
Old Mar 1, 2006 | 08:56 AM
Blackroc86's Avatar
Car: 1986 Iroc
The kickdown cable is the lower cable in this pic.
Attached Thumbnails TH350 change over Bracket - B&M users come in.-image001.jpg
Old Mar 11, 2006 | 08:09 PM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
you need a 82-83 crossmember from a 200c car,and the kickdown cable does not need to be hooked up, the tranny mount that i used was for the year of tranny, i did this on my 82 ta back in 92,
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
Fast355
Dec 2, 2016 06:33 PM
BADNBLK
Nov 16, 2016 09:12 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
