pilot bearing install question.
Old Feb 18, 2006 | 07:53 AM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
I just got this pilot bearing from NAPA. which side do I install facing out? Also how deep do I put it into the back of the crank. It looks like it could go back further than it needs to but I might be nuts.
Pic 1 .
EDIT: I forgot to post the pic of the other side before I left home. Will do it tonight.
Old Feb 18, 2006 | 09:07 PM
The side you're showing, is the back side.
The "front" side (the side you see after it's put in) has a little rubber seal in it, to keep the grease from leaking out around the clutch gear pilot. That side also has a little radius or chamfer to help guide the clutch gear in.
Put it in to just under flush with the surface it goes in; like, .015" - .030" below.
Old Feb 18, 2006 | 09:09 PM
Here's a pic I found on here, of one in a crank.
Attached Thumbnails pilot bearing install question.-crank-w-pilot-bearing.jpg
Old Feb 19, 2006 | 06:28 AM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Do I need to add any additional grease to the bearing? It looks like it is pregreased.
Thanks for the replies. That really cleared it up.
anesthes
Mar 10, 2016 10:35 PM
red90IROCls1
Aug 25, 2015 06:56 AM
gwade12
Aug 8, 2015 08:17 AM
rsrmoore
Aug 7, 2015 08:44 PM
