5 speed tranny 3rd grear grinding
Old Feb 19, 2006 | 04:33 PM
JFROG's Avatar
Car: 84 berlinetta
Transmission: auto
grinds when i go into 3rd gear, is it probably the syncros? about how much will it cost to get fixed at a tranny shop?
Old Feb 20, 2006 | 11:41 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
can;t really tell you how much , but it doesn sound like synchros . Next time try lewtting the revs fall all the way down before you try and slip it in . Get it fixed soon . I let mine go , then there was bearing issues , then I shattered gears and the input shaft. THAT cost me alot of coin !
Old Feb 20, 2006 | 01:25 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
ok blocker ring
which is a part that goes hand and hand with the syncro setup. I have seen the roller bearing cage break and cause the same problem too
Old Feb 20, 2006 | 09:15 PM
JFROG's Avatar
Car: 84 berlinetta
Transmission: auto
yeah only grinds when either upshifting or downshifting, letting the revs come down does help. also does it very little going into first if in neutral clutch out then push clutch in and put in first.
also might temp be a factor? havent tried it yet since it was about 30degrees out. just got the car sat. private seller.
Old Feb 23, 2006 | 03:52 PM
simzjr's Avatar
Car: Camaro
Engine: 383 Stroker
Axle/Gears: 3.73:1
Mine does it to however sometimes i can be sitting in gear with the clutch all the way in and it will make a horrible grinding sound until i let the clutch out. This leads me to believe that it is clutch related however if i leave the clutch in and shift to other gears it sometimes stops the grinding?? Any suggestions here?
bjpotter
Jan 22, 2019 12:27 PM
Cacike
Aug 27, 2015 05:10 PM
19irocz85
Aug 26, 2015 07:54 PM
jbd1969
Aug 17, 2015 07:06 PM
hokis
Aug 9, 2015 03:57 PM
