will a deep tranny pan fit?
Old Feb 20, 2006 | 03:25 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
summit has deep transmission pans with fins and new bolts. since my pan gasket is leaking i think i might as well "upgrade". they are said to fit 700R4 but will that frame brace thing right behind the pan be in the way? how much ground clearance will i loose? does anyone have one installed on their car? pics?
thanks
Old Feb 20, 2006 | 03:48 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Take a look at your stock pan and if it has scrape marks on it, I will let you draw your own conclusion.
Old Feb 20, 2006 | 04:33 PM
rwdtech's Avatar
it doesnt have any scrape marks. im worried a deeper pan wont clear that frame brace thing...what is it called?
Old Feb 20, 2006 | 04:38 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Transmission crossmember.
Old Feb 20, 2006 | 05:17 PM
rwdtech's Avatar
ok thanks, so will the transmission crossmember be in the way?
Old Feb 20, 2006 | 05:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I doubt it. There isn't much benefit to a deep pan to outweigh the lost ground clearance though.
Old Feb 20, 2006 | 07:18 PM
rwdtech's Avatar
they do have cooling fins (lol), all new bolts, new gasket, and a drain plug! that sounds cool they are only 123 bucks too
Old Feb 20, 2006 | 07:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
New bolts, a new gasket and a drain plug kit for a stock pan adds up to a lot less than $123.
Old Feb 20, 2006 | 08:04 PM
rwdtech's Avatar
ok i guess i will get a stock sized pan. i am noticing transmission fluid on that big metal thing that the catalytic converter hanger bolts to (and i think the torque arm bolts to it also) im pissed i didnt get a pic while i had the car up in the air today. its a weird leak because the fluid is comming from one of the bolts...this is too hard to explain, does anyone know what im talking about?
Old Feb 20, 2006 | 08:22 PM
rwdtech's Avatar
ok i managed to find a pic that shows what im talking about, sorry its so crappy
the circle is what im talking about, the X is where its leaking
Old Feb 20, 2006 | 08:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's probably not actually leaking from the bolt, just dripping from it. Sounds like you could use a new rear seal.
Old Feb 20, 2006 | 11:26 PM
rwdtech's Avatar
what exactly is this seal called? what does it take to replace it?
Old Feb 21, 2006 | 12:56 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
That area is well above the oil pan. The seal is called "transmission case extension housing seal" GM pn 1358899.
EDIT: pn is 8673526 is the seal. The 1358899 is the o-ring for the ext housing to the main case.
Old Feb 21, 2006 | 04:08 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
i put the derale tranny pan on her forulma 350
no problems what so ever
i like that pan because of the cooling fins to help cool the filter, so i didn't need to mess with a filter spacing, if you don't use a filter spacing, it's sorta useless
i also like the derale one to prevent sloshing of the tranny fluid, sorta baffled.
i did scrape her pan getting out of a storage garage, but, it was a pretty steep drop, the pan doesnt sit lower then the exhuast
but you'd definately want to make sure you dont have a saggy suspension going over speed bumps.
all in all, a worthy mod
Old Feb 21, 2006 | 05:24 PM
rwdtech's Avatar
good info, just what i was looking for. thanks
Old Feb 21, 2006 | 06:22 PM
Don 79 TA's Avatar
Engine: TPI
no problem
just be leery of the cheaper tranny pans, make sure it has everything
do watch out if you have a lowered car or a TA, since they are slightly lower
get yourself a tranny filter too, good time to change it
Old Feb 21, 2006 | 08:44 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
I used the derale pan for about 10 years. Good price and quality. Bounced it off speed bumps one too many times. I could not get the drain plug to stop dripping because of the impacts, so I removed it.
Jeremys87
Jul 14, 2022 09:08 PM
someone972
Aug 30, 2015 12:52 AM
Thornburg
Aug 25, 2015 01:46 AM
kah992
Aug 19, 2015 02:55 PM
