4l80E ?
Old Feb 21, 2006 | 05:53 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
4l80E ?
I have to do one for a friend and have never been in one. Big deal to do,or no biggie? Parts sure are pricey though. If anyone has any tips, toss them my way.
Old Feb 21, 2006 | 08:29 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
What are you doing, replacing or rebuilding?
Internally, it's almost identical to a TH400 and uses many of the same parts.
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
what year 4l80e? the '96 and earlier were just like a 4oo with an overdrive attatched to the front and an electronically controlled valve body. '97 and up, they changed the lube path and moved one of the cooler lines to the center of the case to provide lube through the center support. in these later versions, the cooler line fitting has to be taken out prior to removing the center support or else you will damage it.
Old Feb 21, 2006 | 08:40 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
This one is a 98 or 99. I will pick up the atsg book regardless. I appreciate the tip though. I already committed to the build, so I guess i will figure it out. I have done 400's, so that may help.
Old Feb 21, 2006 | 08:51 PM
87zjeff's Avatar
it shouldn't be too bad. just be careful with that rear cooler line fitting. there are little differences between '98 and '99. when looking for replacements parts (if necessary), make sure to keep that in mind.
oldred95
Mar 19, 2020 03:03 PM
ZZ3Astro
Aug 13, 2019 12:57 AM
zride91
Aug 22, 2008 10:53 PM
Vortex91
Jul 19, 2007 08:28 PM
Hoss50
May 30, 2004 12:08 AM
