car moves too slow
Old Feb 22, 2006 | 11:24 AM
gijeff350's Avatar
car moves too slow
I just recently installed a rearend from a SLP 2002 camaro into my 86. I also installed a brand new 700-r4 from summit. I built the engine around the edelbrock rpm 350 except mine is a 383. When I had the rotating assembly balance I used my old flez plate. It turns out the flex plate is a little warped. Everything looked like it lined up right when I put it all together but the car lacks the power it should have. Could the warped flex plate be the subject of my problem? I 've tried everything else such as checking for vacuum leaks, spark plugs, and carburetor tuning. If the flex plate is toast can I have a new flex plate balanced to fit the engine without tearing the whole thing apart?
Old Feb 22, 2006 | 12:02 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
What would indicate the flex plate is warped?
Old Feb 22, 2006 | 12:22 PM
gijeff350's Avatar
When I turn the flex plate one side is closer to the starter cog than the other and the plate is mounted fluch agains't the crank.
Old Feb 22, 2006 | 01:38 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Re: car moves too slow
Vibration yes, loss of power, no.
Old Feb 22, 2006 | 04:15 PM
gijeff350's Avatar
Re: Re: car moves too slow
I don't remember any vibration when I ran it the other day. I'll run it again to double check though.
Thank you all for your in put!!!
Azrael91966669
25
Jun 20, 2017 04:04 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
86Base
Aug 8, 2015 01:34 PM
