T56 Clutch Fork Retaining Clip?
Old Feb 23, 2006 | 09:15 AM
92lpeb4c's Avatar
Car: 1992 B4C
Engine: 4-bolt 350 219cam Superram
Does the thin metal retaining clip (which is held on with a rivet) serve an important purpose in the engagement or disengagement of the clutch? The fork I received with the T56 swap-kit I purchased has the clip bent up about half an inch where it meets the 'T' on the fork. Might this cause an issue? Thanks in advance.
Old Feb 23, 2006 | 10:14 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
It holds the fork on the pivot ball stud.
Old Feb 23, 2006 | 10:37 AM
I don't think it's necessary.... IIRC mine doesn't even have it.... but it would have made assembly alot easier. Which is probably why the factory put it there: one little clip is cheaper than having their assembly workers chasing clutch forks around on the floor.
Old Feb 23, 2006 | 11:21 AM
92lpeb4c's Avatar
Car: 1992 B4C
Sorry no pic but I found this online.
Old Nov 21, 2012 | 10:20 PM
oscarfromla's Avatar
Car: 88 Iroc-Z
Engine: 355 AFR-195 FIRST Fuel Inj.
Axle/Gears: ??
Re: T56 Clutch Fork Retaining Clip?
Was the final verdict on this that the clip is not needed? My T56 does not have the clip.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Night rider327
Feb 25, 2016 09:50 AM
mfp189
Sep 27, 2015 09:25 AM
mygta87
Sep 14, 2015 10:36 PM
tonys91rs
Sep 2, 2015 07:07 PM
