torque capacity of rear end
Old Feb 23, 2006 | 11:29 AM
joel lopez's Avatar
Car: 1982 trans am
Engine: 406 small block
Transmission: turbo 350 with 2500 stall
Axle/Gears: 7.5'' hardened axels aurburn pro 3.73 gear
I have a question about my rear end. It is a 7.5'" with a auburn pro diff 3.73 gears and after market axels. my question is how much can these little things really take? I have a 406 sb. with edelbrock rpm heads that makes in the neighborhood of 450+ horse. this year i hope to get it to the track. I would like to run slicks, but I'm not sure if i should. I would hate to gernade it after investing all that money into it. Should i sell it and buy a 12 bolt?
Old Feb 23, 2006 | 11:55 AM
ede's Avatar
ede
384 ft/lbs is the max a stock 10 bolt can handle
Old Feb 23, 2006 | 12:10 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
it will handle more with an auto tranny.
Old Feb 23, 2006 | 12:11 PM
joel lopez's Avatar
Car: 1982 trans am
Is that the stock rear end, at the rear wheels or at the flywheel?
Old Feb 23, 2006 | 12:20 PM
put a stud girdle cover on it if you haven't yet.
Old Feb 23, 2006 | 03:07 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
Hard to say but it definately wont be bullet proof with slicks and hard launches.
Old Feb 23, 2006 | 08:02 PM
joel lopez's Avatar
Car: 1982 trans am
thanks for the help guys
Old Feb 23, 2006 | 10:47 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
slicks should come with a guarantee card when your using a 10bolt rear, if you dont break it with slicks somethings terribly wrong!
The auto does soften the blow a bit but a couple of dead hooks and it will be in the passenger seat with you...
Old Feb 24, 2006 | 09:39 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
How much help would a stud girdle be in terms of adding torque capacity to the rear end?
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
hectre13
Aug 26, 2015 08:17 AM
