governer removal
Old Feb 24, 2006 | 02:26 AM
KILGORE92's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Axle/Gears: 323 std
governer removal
my car tops out at 110 but i know that my engine has more to give how do i get rid of the governer
Old Feb 24, 2006 | 03:37 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
There's no governor in the transmission. There is a speed limiter programmed into the chip. For most TBI's (from '89 on) the cutoff was 108 mph.
Since the TBI cars use an external VSS buffer, you can trick the ECM by following this tech article, Overcoming the speed limiter in TBI equipped F-bodies.
Your other option is reprogramming the chip. If you choose that method, you will be reading a lot Grumpy's posts in the DIY Prom forum. Here's one about the '747 ECM to get you started, Programming 101, the beginning.
Old Feb 24, 2006 | 06:30 AM
Pro Built Automatics's Avatar
All 700R4's have governors. It is the 4L60E's that do not use a governor.
Old Feb 24, 2006 | 07:45 AM
Jade Grey's Avatar
Engine: 305TPI
Sorry I phrased my statement incorrectly. I should have said his problem was not the governor in the transmission.
Doesn't the governor in a 700R4 calibrate the shiftpoints?
Old Feb 24, 2006 | 09:24 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Yea...the governor controls the WOT shift points, part throttle shift points, etc.
How hard is it to do one? I've been thinking about taking mine out and putting in a 5200rpm vette unit. Thanks.
Old Feb 24, 2006 | 02:51 PM
KILGORE92's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Axle/Gears: 323 std
so the governer that i want to get rid of is the one thats in the computer but if im switching it to tpi i wont have that problem?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
