TH350 parts/brackets
Old Feb 25, 2006 | 07:37 AM
Shake Zula's Avatar
Car: 1986 Olds Cutlass Supreme
Transmission: 200-4R
Axle/Gears: good question...
My th350 dosent have any brackets or hardware. What all do I need? Shift cable, shift cable bracket? I have a Hurst rachet shifter, so do I have to have a TV cable or I can I just manualy shift all the time? Will anything from a 700r4 work?
Old Feb 25, 2006 | 01:09 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
The TH350/400 dont use a TV cable, just a kickdown cable. So you can run these without the cable, you will just have to manually drop gears.
If it was a 700R4 it has to have the cable, no ifs ands or buts!
Your also going to need the torque arm relocation brackets if you do not already have them.
Old Feb 25, 2006 | 01:23 PM
Shake Zula's Avatar
I know about the torque arm conversion kit, just wasnt sure about a TV/Kickdown cable.
Dose Summit sell the shift cable and bracket in a kit? Or Autozone?
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
romcjr
Sep 17, 2015 05:18 PM
LittleFranks
Sep 17, 2015 12:22 PM
89newfun
Sep 16, 2015 09:28 AM
383cam
Sep 9, 2015 06:01 AM
