Gearing questions for my combo
Old Mar 1, 2006 | 01:32 AM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Hey.
I currently have 3.27 gears in my 9bolt.
The setup in my car is as follows;
357ci
Holley Stealth Ram intake
Edelbrock Performer RPM Heads
Comp XE 224/230
.513/.510 lift with Crane Gold 1.6rr's
Pro Yank 3400 stall
The Car most likely has peak HP at around 5800 rpm.
Would I see much of an improvment swaping out the 3.23 gears for some 3.70 gears? I know my car would be trapping a lot closer to the peak HP level so that should help and maybe gain some ET and MPH?
Traction shouldnt be much of a problem as I will be running MT ET Street radials.
thanks
Edit - Just noticed I accidently put this in the wrong forum and I can't delete it. Can somone move it? thanks.
Old Mar 1, 2006 | 02:57 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
You will probably shave some off your ET, but MPH will likely stay the same.
1984HO
Mar 19, 2021 11:59 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
