junkyard posi
Old Mar 1, 2006 | 06:37 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
junkyard posi
Im gonna be going to the yard soon to try and get a few more items I still need, t5 inspection cover, VSS if i can find one (doubt i will, will have to find the part #'s again and order one i figure), new gears
torque arm mount?? im still unsure if thats a unique peice or the 700r4 one is the same
is it worth grabbing a posi unit if I can find one? Im under the impression they will simply all be burned out at this point, and I dont know which ones if any are rebuildable or what.. but I cant afford no $400+ unit right now
if its not worth looking for a used posi, then ill likely just grab a 3.42 or 3.23 open diff, since that will be easy to find
Old Mar 1, 2006 | 08:23 PM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
Axle/Gears: what ever stock is
if i remember correctly, all v6 models or at least most come with 3.42 gears. i've been told that if you pull the cover off, as long as there's not chunky sh*t in the housing, that it should be good. id do it.. you could probably get it for about 50 bucks.
Old Mar 1, 2006 | 09:33 PM
brutalform's Avatar
Torque arm mounts differ from the T-5, to the 700R4. You'll have to get the correct one.
Bubbajones_ya
Oct 25, 2015 08:01 PM
KO1
16
Oct 15, 2015 05:00 PM
