Lockwashers on flywheel bolts?
Old Mar 4, 2006 | 04:13 PM
Overspendin''s Avatar
Car: '88 IROC Convertible
Engine: ZZ4 TPI
Transmission: 5 spd.
Sorry, may be a dumb question but I'm swapping out an auto for a T-5 and I don't have anything but a very dirty Hanes manual for refferance.
Do the flywhhel bolts require lockwashers?
Old Mar 4, 2006 | 04:17 PM
brutalform's Avatar
There are no dumb questions, when it pertains to safety. Not lock washers, but those "star" washers. Make sure you use NEW flywheel bolts, and they will come with them on them, and put a dab of loctite on each one. Alot of people say, "you dont have to add new bolts", but if your there, you might as well. Make sure you torque to specs in a cross pattern.
Old Mar 4, 2006 | 04:19 PM
Engine: ZZ4 TPI
Thanks Brutalform, I have the new bolts, I'll have to run down to the store for new washers.
Old Mar 4, 2006 | 04:20 PM
brutalform's Avatar
What kind of bolts are you using?
Old Mar 4, 2006 | 04:31 PM
Engine: ZZ4 TPI
New flywheel bolts from GM.
Old Mar 4, 2006 | 04:44 PM
brutalform's Avatar
OK, and they did not come with the washers, huh?
Old Mar 4, 2006 | 05:09 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
GM does not use washers. They use a shouldered bolt. The washers are commonly used in aftermarket bolts and surely cannot hurt. Be sure to check that you have enough thread engagement if using washers though.
Old Mar 5, 2006 | 12:51 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
ARP Bolts also recommend not to use washers. They just recommend using the ARP lube on the underside of the head and on the threads and torque them to 75lbs
Old Mar 5, 2006 | 01:20 AM
Engine: ZZ4 TPI
If I'm reading my manual (wipe away the grease) correctly, the torque specs are 30lbs. ARP's are that much higher? Or do I have the wrong info?
30 lbs. did seem pretty light to me.
Old Mar 5, 2006 | 07:44 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
The arp is likely higher because they use no thread sealer and use a very low friction lube. Otherwise, bolts have a torque spec because we are unable to measure bolt stretch. Different bolts require different specs because they require a different stretch. Long story short, follow bolt manufacturers spec.
Old Mar 5, 2006 | 01:02 PM
brutalform's Avatar
"I see", said the blind man, to his deaf son! We'll that explains why he has no washers. I knew the aftermarket bolts, like Mr. gasket, had them. did not know about the GMs though.
Old Mar 5, 2006 | 02:43 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The 30 ft/lb is for the clutch pressure plate to flywheel bolts.
Flywheel to crankshaft bolts are 74 ft/lb.
Bellhousing to engine block are 35 ft/lb.
These specs are for a V8 from a '92 Helms service manual.
HTH's,
RBob.
Old Apr 15, 2006 | 06:22 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
I ordered Gm flywheel bolts and they didnt have a flange or washers.
The shorter flexplate bolts I took off did no washers needed.
Old Apr 15, 2006 | 09:32 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
OEM bolts = blue Loctite & no lockwasher. Torque to 75 ft lbs.
Aftermarket bolts = lockwashers ( if suppied with bolts) & blue Loctite. Torque to 75 ft ls.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stangski09
Nov 14, 2015 01:27 PM
Nick McCardle
Sep 10, 2015 08:36 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
