shift kit or reprogrammer kit
Old Mar 9, 2006 | 12:02 PM
wiseman9986's Avatar
Car: 82 z28
Transmission: TH350
Axle/Gears: 10 bolt 3.73
is a shift kit and a reprogrammer kit the same sorry prob a dumb ? thanks
Old Mar 9, 2006 | 12:05 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
differences
Im pretty sure a reprogrammer kit is for a electronic controlled transmission that you can plug the kit in and change the shift points. A shift kit comes with bands and springs to modify the valve body to reroute the fluid to make it shift harder and give you manual control
Old Mar 10, 2006 | 08:41 PM
91drag's Avatar
Car: 1928 dodge coupe, 64 1/2 mustang
Engine: 350,289
Transmission: munice 4 speed,c4
Axle/Gears: 9" 3.00, 9" 3.25
some shift kits are called reprogramer kits i have a stage 4 kit and it says reprogger kit on it so i belive they are the same .i have a th 350 trans
Old Mar 11, 2006 | 03:55 PM
Car: 82 z28
Transmission: TH350
thanks i was pretty sure that is what it was
Old Mar 11, 2006 | 08:20 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
In the TransGo world the difference between a shift kit and a reprogramming kit is such: The reprogramming kit has additions that enable 1st gear to be held to any speed. It also has the option of a full manual valve body. This is along with everything the shift kit offers.
The TransGo shift kit creates a better shift. Increased line pressure, faster shifting, and a better hold is the goal here.
RBob.
Old Jul 26, 2007 | 12:05 AM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
Re: shift kit or reprogrammer kit
RBob.
Sorry to dig up an old post...but to anyone here.. is this saying that the transgo shift reprogrammer is the exact same as transgo shift kit but with extra features? Or is this saying that they do similar, but different things but the transgo shift kit creates a BETTER shift (than the reprogrammer)?
Old Jul 26, 2007 | 04:19 PM
Pro Built Automatics's Avatar
The reprogramming kit from TransGo is the same as the Performance Shift kit. The difference is the video is offered with the Performance Shift kit. The regular Shift kit is totally different, and is offered in two versions. I have another version, the reprogramming kit from TransGo, combined with the TransGo Junior Shift kit. This setup offers smooth part throttle shifts with the shifts getting firmer with more throttle.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
