Non lockup converter
Old Mar 15, 2006 | 07:32 AM
millerbn's Avatar
Car: 89 RS
Engine: 383, forged bottom end, 10.5 to 1 compression, GM fastburn vortec heads, Reed roller cam, roller rockers, Edelbrock air gap intake, Holley 4150, MSD Pro Billet
Transmission: Bowtie Overdrives Level 3
I'm thinking of getting a non lockup torque converter. I know gas mileage will suffer, but this really isn't an issue because the car is only driven occasionally on the street. I also know heat is an issue, but I will add a transmission cooler. What other issues are involved. Will transmission mods be needed? I know that this has been discussed before, but search is down and I can't find the posts.
Old Mar 15, 2006 | 07:42 AM
brutalform's Avatar
I really do not see what the benefit would be, or the money spent on it. Alot of people are running lockups on the street, and strip. Now if you were going to do up a TH400, or a TH350, then I can see it. But, since you have a lockup trans, why not just get a new lockup converter with a more optimum stall for your combo?
Old Mar 19, 2006 | 02:16 PM
millerbn's Avatar
Car: 89 RS
Well, I have a carbed motor with all ECM functions gone. In fact, the ECM isn't even in the car. I'm going for optimum stall for my motor. I just wondered if my transmission (Bowtie Overdrives level 3) would be able to handle a non-lockup converter without modifications.
Old Mar 19, 2006 | 06:46 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
If you wish to do away with lock up, remove the front pump and install a non lock up pump valve. They are available in the aftermarket for about 30 bucks. You MUST install this valve or the trans will die.
The other option is to install a 4th gear only lock up kit. 1/2 hr install once the pan is down. It will only require a 12v ignition power lead run to it. Then it will lock up from fluid pressure when it shifts into 4th gear. I recommend it if going in a street car.
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
