tranny fluid
Old Mar 21, 2006 | 07:00 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
tranny fluid
700R4 uses how many quarts? what type of fluid does it use, i forgot....
Old Mar 21, 2006 | 07:35 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Dextron 3 is the type. Total fill for empty trans and converter is approx 11 qts. More if a deeper than stock pan is used.
Old Mar 21, 2006 | 07:37 PM
rwdtech's Avatar
hmmm i just found my haynes manual and they said 4.7 quarts of dexron II. im just dropping the pan and filter. can i put dexron III in there even if it came with dexron II?
Old Mar 21, 2006 | 07:41 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Dextron 3 supercedes dextron 2. It will be fine. For a pan drop only, 5 qts on hand should be enough.
Old Mar 21, 2006 | 08:00 PM
rwdtech's Avatar
right on, thanks
Old Mar 22, 2006 | 06:32 AM
Pro Built Automatics's Avatar
It is Dexron, not Dextron.......
Old Mar 22, 2006 | 12:53 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Thamk fore the spell chech.
Old Mar 22, 2006 | 11:37 PM
rwdtech's Avatar
i pulled the pan today and found an 8mm bolt on the magnet. that really scared me. turns out it screws into what i think was an accumulator, not the valve body. its a cylinder shaped metal piece right above the magnet. i tightened it back in. tranny shifts smoother now because of the new fluid. the fluid was very clean and i didnt get any metal shavings besides the normal build up from the band wear. so far the rubber gasket hasnt leaked. one of the pan bolts under the tranny cross member got cross threaded...there was nothing i could do about it. a tap wouldnt fit in there. i just monkied it down and hoped for the best. oh well....i dont plan on changing the fluid for another 40k miles and i will die before i put that kind of milage on the car
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
HoosierinWA
Oct 7, 2015 10:15 AM
bjpotter
Oct 4, 2015 07:48 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
