Stock Torque Converter for 84 Trans Am
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Does anyone know the stall speed of the stock Torque Convertr that came standard in the 1984 Trans Am's with a 700R4 and 305 H.O. motor? I'm looking at installing a new cam and need to know what sort of stall speed the stock converter has. Thanks in advance for any assistance you can provide!
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I'm fairly certain all thirdgen V8 automatics came with 1600 rpm stall converters.
Car: 1984 Trans Am
The reason I ask is that the cam I am looking at says it requires a 2000rpm stall. Comp Cams confirmed that I will need a stall converter for best effectiveness. So if the stock is 1600, then I'll need to start looking at a new stall converter. Thanks for the info!
1992 Trans Am
May 10, 2023 07:19 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
