No fluid in the cooler lines
Old Mar 22, 2006 | 01:19 AM
Bluejae's Avatar
Car: 1988 Formula 350
Engine: L98 350 TPI
Transmission: 700-R4
Well after dropping the "new" bad transmission while removing them, there was no oil in the lines. I drove the car around for a while, less than two miles, but I didn't have the TV Cable set up correctly. I didn't have the original TV Cable because the flywheel ate it one day while starting the car to keep the battery charged. So I used one that came with the tranny which is an aftermarket one specifically for Cameros and Firebirds. So wouldn't there be oil in the lines if they were not plugged with particals when the original tranny shot to crap. Sorry if this doesn't make sense, I can barely understand what I am saying. Thanks to anyone reading and/ or answering.
Old Mar 22, 2006 | 03:50 AM
EvilCartman's Avatar
Car: '82 Z28
My brain hurts from reading that Were the lines dry? You should have cleaned them out before installing the new trans. Speaking of which, do it now to see if they are plugged.
Old Mar 22, 2006 | 09:46 AM
Bluejae's Avatar
Engine: L98 350 TPI
Yes the lines were dry. The car sat for 9 months before I bought a new tranny, so whatever was in the lines surely dripped out. I plan on flushing the lines and cooler before putting the new tranny in. Sorry about the post, when I wrote it thats how it came out from my head and I tried to correct it, but just couldn't fix it. I don't know why I didn't flush out the lines the first time around, I just wasn't thinking.
Old Mar 23, 2006 | 05:44 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
If I'm not mistaken fluid doesn't normally flow until the TCC locks up. With no TV cable (or a maladjusted one), and especially if you didn't get over 40+mph in that 2 miles, it would not surprise me if the lines were still dry.
Old Mar 23, 2006 | 07:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, there's always flow through the cooler.
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
fluid still flows even if the tcc isn't locked. if it didn't, you wouldn't have fluid pressure to apply pistons, lube, or anything. sounds to me like something is plugged.
Old Mar 24, 2006 | 06:56 PM
bobdole369's Avatar
Car: 1989 Firebird
My mistake, and now that I think about it, I distinctly remember watching a TH200 on an 82 crossfire pace car ooze like blood when the tranny line crossthreaded at the radiator after a replacement. Sorry
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Numbah-1
Sep 12, 2015 08:57 PM
TBRays98
Sep 6, 2015 05:05 PM
apie2546
Sep 5, 2015 07:40 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
