carrier swap
Old Mar 22, 2006 | 01:45 AM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
carrier swap
i need to know what i need to do to swap carriers....as far as gears go the only thing (i beleive) that will be touched is the ring gear to go from the old to new carrier... if all that is being replaced is the carrirer do i HAVE to or should redo everything (shims, spacing, and what not) or is it a direct swap...what tools do i need to check everything....
i don't know if it matters but the rear will be out of the car while i'll be doing this....and dealing with the rear end is new to me so be kind
Old Mar 22, 2006 | 02:02 AM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
You should redo the spacing. Start out with the setup from the original carrier but it might be different so be ready for that. You will probably need to pick up something to show you the correct wear pattern and a good marking compound for the ring gear and this will help you shim the new carrier also. Take your time is probably the best advice you can get.
Old Mar 22, 2006 | 04:00 AM
ede's Avatar
ede
you'd need to swap the ring gear over and install the carrier. then set back lash to around .008. you might want to check back lash before you remove the original carrier and replicate that number. you may have to change the shim arrangement but not the total shim thickness. i wouldn't worry too much about checking the contact pattern.
Old Mar 22, 2006 | 12:10 PM
chio987's Avatar
Engine: 305 4bbl HO
what's the tool i need to check the back lash.....r there any how-to's anywhere to help me???
Old Mar 22, 2006 | 01:14 PM
Engine: 355 chevy
you need a dial indicator with a magnetic base! You can get them out of jeg's or summit but they are pricey.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
knight72
Aug 10, 2015 09:32 PM
