Ignition Wiring With B&M please help!!! :(
Old Mar 23, 2006 | 10:52 AM
89TransAmWS6's Avatar
Car: 1989 Trans Am WS6
Engine: 305 5.0L 171RWHP, 263 RWT
Ok I've pretty much ruled out my alarm as causing the problem, since I reconnected it etc..
Anyways, all my reverse lights work and crap, but my *** damned car WILL NOT crank for the life of me.. what wires can I wire together to the neutral saftey switch (sans relay) and have my car start??? Or what can I put together to make it start in all gears??? I just want to try starting the car, if it doesn't start then, I'm going to rip out my alarm, if that doesn't work, I'll go looking for a fusible link somewhere... But anyways, please someone tell me how I'd wire this thing w/o the relay.. I don't want to cook anything!!!
Old Mar 23, 2006 | 02:19 PM
I figured it out, the instructions are written differently then what the diagram shows.. weird
Old Mar 24, 2006 | 07:15 AM
link85x's Avatar
Car: 1988 IROC-Z
Axle/Gears: 10-Bolt w/3.08's (dying)
Which pisses me off somewhat. So you just wired it straight to the shifter from the stock harness, without the use of a relay?
Old Mar 25, 2006 | 01:12 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
The Purple and Yellow wires.
Sounds like you don't have the neutral switch adjusted properly on the shifter.
Takes some fiddling around and patience. I did it with a volt meter hooked up so I could see what it did and when.
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
