Good Cruising Gear
Car: 1992 Z03 RS
Engine: (L03) 305TBI
Transmission: TH-700R4
Axle/Gears: bone stock
Good Cruising Gear
I enjoy shifting through my 92' RS 700r4 sometimes but I also like keeping it in a single gear too. I have been keeping it in 2nd around town from about 30-45mph. Is this ok to do? I know when I shift up into 3rd the rpms drop around 45mph so does that mean when I run it to 45 in 2nd its hard on the engine if I leave it there? Basically, what is the best gear to drive about 40-50mph in 2nd or 3rd?
Car: 1989 Firebird Formula
Engine: LB9 305 tpi
Axle/Gears: open 2.73's baby!!
im answering this question from experience on other cars so if its a little off for the 700r4, please forgive me (havent gotten a chance to drive the Firebird that fast yett), but at 40-50 mph im pretty sure ur going fast enough to go into 4th gear, or OD, that would be the easiest on the motor since its turning a much less rmp to maintain the same speed, in turn ull do much less wear and tear on the motor. hope this helps some
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yep, about 40mph the trans will go into overdrive... and my torque converter will lock up at that point to go into overdrive
i wouldnt be leaving it in second while cruising 30-50mph... it increases stress on the trans.. i'd just keep it in drive or upshift to drive when ur just cruising. its an auto... not ment to be driven like a stick. save the gas and lower ur rpms.
i have 3.27 gears and in overdrive, i can putts around 65-70 at around 2000rpms all day. its a good gear for decent performance and good mileage at the same time.
to maximize a motor running a power peak of 4500-5000rpms like TPI in a 700r4 and 25.7-26inch tire (street tires or slick), go with a 3.42 gear. 3.73 will be slightly higher and more suited to a car with a peak in the 5000-5500 range. 3.42's will keep nice driving to with the overdrive. for all around good driving with that 4500-5000 peak rpm motor, 3.23 or 3.27's are sweet.
Engine: LB9 305 tpi
wow if ur at 2k rpms at 65-70mph what would i be at with my 305 and 273's? will i have a decent gas mileage? lol thanks for the help
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
