major problems at wot 700r4
Old Mar 25, 2006 | 10:06 PM
anthony64ss's Avatar
Car: 1984 Z28
Engine: L31
Transmission: WC T5
Axle/Gears: 10 bolt 3.73
This problem is really confusing me. *background*Car is an 85 camaro TPI 70,000 miles. 700r4 not original, unknown miles, but its an 87+ i guess its in ok shape. the whole Tv system has been replaced due to a sticking tv valve/broken cable. i fixed that about 2 months ago. adjusted correctly. that didnt fix 2 problems though.
1) i have an extremely violent bucking at wot. this occurs at about 4500rpm and it bounces violently betwwen 4250-4500 rpm when it does this. its like the trans doesnt want to shift. thought it was the governor, but i just replaced that today no luck.
2) i cannot, for the life of me get this thing to rev past 4700 rpm *in gear* revs fine in neutral. before it was more like 4500, but i put in a v-6 governor from bowtie overdrives today. he said it would give me about a 5200rpm shift. im stuck at 4700. its like the car hits a brick wall. im pretty sure its a tarns problem since it revs fine in neutral. could be mistaken though. i need to check fuel pressure...
anyone pleaaaaase help me
im lost at this point
Old Mar 26, 2006 | 12:09 AM
incognyto's Avatar
could definatly be fuel probs, maybe weak spark (coil), to large of spark gap, hopefully the torque converter lockup isn't locking and unlocking, I have a manual switch, I'm kinda taking shots in the dark here, let me know if it's already fixed could also check trans pressures and see what's up, I have a autometer trans temp gauge I would also like to get a permanent pressure gauge for the trans so I can see it all the time, not sure how that would affect actual pressure haveing a gauge wired to it all the time, even if it's 4000 PSI hydraulic line. regardless ... TTYL
mdtoren
Aug 23, 2015 12:52 PM
zeitghaist
Aug 18, 2015 07:33 AM
mdtoren
Aug 16, 2015 05:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
hokis
Aug 9, 2015 03:57 PM
