700r4 TCC plug and receptacle
Old Mar 27, 2006 | 10:56 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Working on an 86. The receptacle is set in the tranny case on the driver's side. It is the one where the four wire TCC plug goes.
I have a new plug with pigtails and a new receptacle with o-ring. It looks like I need to drop the pan to remove the receptacle ? Anybody know for sure how it comes out ?
I just did a tranny fluid and filter less 5,000 miles ago so if I don't have to drop the pan that would be great...........THX for any info.
Old Mar 27, 2006 | 11:01 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Look closely at the bottom side of the case plug. You will see 3 tabs that retain it to the case. Take an 11/16, 12 point, deep socket and slip it over the 3 tabs. Then gently push the socket while you wiggle the plug, and pull it out. Install a new o ring on the new connector and a thin smear of rtv (on the o ring)for good measure.
Pan must come down.
Old Mar 27, 2006 | 11:09 PM
Jetmeck's Avatar
Pan must come down.
Thx for the info. I figured I would have to drop the pan.
About 5k ago I put a new TCC servo in and cleaned the connector up, if I would have been smart I would have changed it then. Thx
Old Mar 28, 2006 | 05:13 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Put that pan plug in while your there this time - I sure wish I had!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
