help!!!! all the bolts holding the torque arm bushing is stripped
Old Apr 2, 2006 | 10:02 PM
86interceptor's Avatar
Car: 86 Z-28 Police Interceptor
Engine: 305 but building a 350
Transmission: 700r4 with shift kit
the stupid mechanic I had put my 350 turbo trans in stripped all the bolts that hold the bushing to the trans. by the way I am using the transdapt conversion kit that uses the stock 700r4 tail housing. how do I fix this???
Old Apr 3, 2006 | 03:44 AM
ede's Avatar
ede
weld the holes redrill and tap, heli coil, use nuts on the bolts, drill and tap one size bigger, drill and tap to one size bigger in metric ( often can do it with out a major increase in the bolt size)
Old Apr 3, 2006 | 10:33 AM
I was afraid that the metal would be to soft to hold a heli coil??
Old Apr 3, 2006 | 11:48 AM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Stripped
Just locktite, RED, the Heli Coil in there and should be
good to go
later
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
