Shift Kit is in, Engine Stalls on Startup
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Hey guys, just got the Transgo shift kit into the Iroc...after alot of swearing, throwing, and kicking, it ended up working out, but I have one issue:
This has happened 3 times thus far. I will go to start the car, and the engine will crank, and detonate, but it stalls, like the tranny isnt catching it. I can hold the engine at about 3000rpm and it just wont catch and if i let off it stalls. Then, one or two more tries later, it catches...any ideas? Could this be that the band is too loose? I checked for clearance, and it was about 3/16 of an inch of play which was what the video claimed was the maximum you wanted it, while shimming the servo.
Car: check
Engine: check
Transmission: check
If you pulled the crossmember and lowered the trans to help with the install, check the distributor. May have wacked the firewall with it.
RBob.
RBob.
No, I didn't have to touch the mount, but I will re-check my timing. Any other ideas?
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
what about the TCC swtichs in the trans, you could have pinched a wire or mess something up in there. I think sometimes the TCC swtiches can go bad causing it to enagde to early or later or soemthing.... right anyone else?
dhonda200
Aug 11, 2015 11:50 PM
