T5 PROBLEM
Old Apr 4, 2006 | 01:50 PM
#rdgearslammer's Avatar
Car: 84Z28
Engine: 310
T5 PROBLEM
this is goin to be kinda lon ill get to the point as fast as i can
ok guys here is my problem. not to long ago i slamed third gear and blew it not the first time hints my username. well i found out that my slave cylinder has a ver small leak. so i tend to loose pressure and fluid for i have to fill it again with fluid. so i got the tranny rebuilt (if anyone in the dallas area needs a manual rebuilt i can most likely get you the best prices around price on mine was cheeper than any other place and he works with my uncle so he cool let me know if anyone need anything rebuilt being a manual) i put it back in and bleed the clutch and everything (not the new one) but i didnt get any pressure back and couldnt switch gears what do you guys think it is any suggestions.
MANNY
Old Apr 4, 2006 | 02:25 PM
The Happy Viper's Avatar
You replaced the slave cylinder with a new one, correct? If you don't have clutch pressure, then it isn't properly bled or is defective. Is the piston on the slave touching the clutch fork? How did you bleed it? Is the TO bearing in right? I need a little bit more info.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
