tranny filters
Old Apr 4, 2006 | 03:00 PM
Tim Hunsinger's Avatar
Car: 91 RS,
Engine: 406ci
Axle/Gears: 2.77 9 bolt
tranny filters
I've seen remote trans filters that use an automotive oil filter so that you can filter the trans better than the stock screen. Do these affect the performance of the trans at all (lower pressures, etc)? Are they a good idea?
Old Apr 4, 2006 | 05:02 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
they are a good addition, wouldn't say its that necessary though as long as you have recently changed the filter.
doesn't hurt either,and adds cooling too.
just fill the filter with oil when you set it up
and use good hoses and clamps
Old Apr 4, 2006 | 10:02 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I run my line though the factory radiator cooler, then through a B&M super cooler then through a permacool remote filter with a Motorcraft FL1A filter, and then back. 20K on this setup and the 89K tranny is running cool and working great behind the 383.
Old Apr 5, 2006 | 04:17 PM
Car: 91 RS,
Engine: 406ci
Great!
Thats what I wanted to do too. Seems like everytime I drop the pan it is full of silvery/gray goo and I'd like to reduce that.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
thejimsterz28
Sep 30, 2015 08:52 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
